Старый 06.07.2016, 20:13   #1
DynamicsAxSCM: Running the allocation step of Wave processing in parallel
Источник: https://blogs.msdn.microsoft.com/dyn...g-in-parallel/
This blog post applies to Microsoft Dynamics AX 2012 R3 CU11 and KB 3153040. Wave processing is used to generate work for the warehouse. The processing can be time consuming and majority of the processing time is spent in the allocation step and in the work creation step. It is now possible to run the...
Kriki: Parallel processing in Dynamics NAV Blog bot NAV: Blogs 0 15.05.2016 18:12
DynamicsAxSCM: How to support a case picking operation using wave containerization in AX2012R3 Blog bot DAX Blogs 0 19.11.2014 16:11
crminthefield: Optimize CRM 2011 Service Channel allocation for multi-threaded processes using .NET Task Parallel Library (TPL) and a thread-local service proxy Blog bot Dynamics CRM: Blogs 0 12.09.2012 00:11
DynamicsAxSCM: Setup for Processing Inbound Pallet Transports Blog bot DAX Blogs 0 14.12.2009 21:05
DynamicsAxSCM: WMS in Microsoft Dynamics AX 2009. Outbound Process Setup Blog bot DAX Blogs 0 27.04.2009 03:23
Часовой пояс GMT +3, время: 21:55.
