Старый 09.08.2016, 19:13   #1
25,644 / 848 (80) +++++++
stoneridgesoftware: Enterprise Portal Error During Creation of EP site
Источник: https://stoneridgesoftware.com/enter...on-of-ep-site/
Symptom:
I am trying to install Enterprise Portal (EP) on a two-server SharePoint farm (1 application server and 1 Web Front End server (WFE)). But the EP install keeps failing at the creation of EP site collections.
This is what I see in the dynamicssetuplog.txt file –
Custom event details:
Error: The Web site http://EPServerHostName:80/sites/DynamicsAx was not created correctly.
Server was unable to process request. —> Could not load file or assembly ‘Microsoft.Dynamics.Framework.Data.AX, Version=6.3.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. Either a required impersonation level was not provided, or the provided impersonation level is invalid. (Exception from HRESULT: 0x80070542) —> Either a required impersonation level was not provided, or the provided impersonation level is invalid. (Exception from HRESULT: 0x80070542)
Cause:
Rights issue with the service account that is running the Claims to Windows Token Service
Resolution to Enterprise Portal error during creation of EP site:
Give the service account for Claims to Windows Token Service the rights listed below.
1.  First, check what account is used to run this service in SharePoint central admin by going to Security then click on Configure service accounts.
2.   Click on the drop down by Credential Management (in the field Select one…)
3.   Select Windows Service – Claims to Windows Token Service.  Note the domain account in the field below “Select and account for this component”.  It will be something other than Local System. This is the service account you need to make sure has the rights permissions list below.
Note:  If you are having this issue your service account listed will be a domain account, and something else, not Local System. For example: Domain\SRV_ClaimstoWin
a.      Set the following local policy rights on both the Application server and the WFE server(s) for the above service account (“Domain\SRV_ClaimstoWin”) by running GPedit.msc, then navigate to Computer Configuration> Windows settings> Security settings> Local settings> User rights assignment
1.    Act as part of the Operating System
2.   Impersonate a client after authentication
3.   Log on as a service
b.     Make that service account a local administrator on both servers (Application server and WFE)
4.     Run iisreset on both servers
5.     Restart the “Claims to windows token” service on both machines from Windows services (Start> run>services.msc)
After all these steps we were able to get over the error and Enterprise Portal site collection was created successfully.
emeadaxsupport: Form Based Authentication (FBA) with Enterprise Portal on AX 2012 allows FBA user to modify the EP site. Blog bot DAX Blogs 0 14.09.2012 03:21
emeadaxsupport: Cannot create Enterprise portal site with SharePoint 2010. Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml' Blog bot DAX Blogs 0 15.08.2011 23:11
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
emeadaxsupport: How to change authentication of an existing Microsoft Dynamics AX 4.0 Enterprise Portal (EP) site to use IIS Basic Authentication Blog bot DAX Blogs 0 29.03.2010 21:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Часовой пояс GMT +3, время: 18:53.
