Старый 26.10.2016, 19:11   #1
organicax: Vendor invoice line workflow
Источник: https://organicax.com/2016/10/26/ven...line-workflow/
If you are setting up workflow to approve vendor invoices you might want to consider if you have approval at the invoice header level or at the line level. The line level would allow you to have multiple approvers for the different lines of a vendors invoice if they needed to be split out for example if the vendor provided one invoice for multiple  purchase orders. There is a workflow for this which is the vendor invoice line workflow.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Accounts payable
Nav developer: Table Information including Index information (Usage, Blocks and Reads) Blog bot Dynamics CRM: Blogs 0 25.08.2009 19:34
NAV Sustained Engineering Team Blog: Index Usage Query Blog bot Dynamics CRM: Blogs 0 26.02.2008 12:29
Часовой пояс GMT +3, время: 04:10.
