Старый 24.02.2017, 14:11   #1
25,644 / 848 (80) +++++++
vasantharivali: Export your AOT Custom Objects Automatically
Источник: https://vasantharivali.wordpress.com...automatically/
Hi,
Here I have posted a job to export all our newly created projects / jobs / any AOT objects as XPO automatically.
static void VAS_ExportXPO(Args _args)
#AOT
FileIoPermission perm;
ProjectListNode projectListNode;
ProjectNode projectTreeNode;
TreeNode treeNode, jobTreeNode;
TreeNodeIterator iterator, jobIterator;
str projName;
str exportProjName = ‘VAS_’;
str jobName;
str exportJobName = ‘VAS_’;
int noOfProjects;
int noOfJobs;
str folderpathProj, folderpathJobs;
#define.ExportMode(“w”)
folderpathProj = strfmt(@’C:\Vasanth Arivali\XPO Backup\%1\SharedProject’, date2str(today(), 321, 2, 3, 2, 3, 4));
folderpathJobs = strfmt(@’C:\Vasanth Arivali\XPO Backup\%1\Jobs’, date2str(today(), 321, 2, 3, 2, 3, 4));
WINAPI::createDirectoryPath(folderpathProj);
WINAPI::createDirectoryPath(folderpathJobs);
perm = new FileIoPermission(folderpathProj, #ExportMode);
if (perm == null)
return;
perm.assert();
projectListNode = SysTreeNode::getSharedProject();
iterator = projectListNode.AOTiterator();
treeNode = iterator.next();
while (treeNode)
projName = treeNode.AOTname();
if ( exportProjName == substr(projName, 1, 8))
// BP deviation documented.
treeNode.treeNodeExport(folderpathProj + ‘\\SharedProject_’ + projName + “.xpo”);
noOfProjects++;
jobIterator = TreeNode::findNode(@’\Jobs’).AOTiterator();
jobTreeNode = jobIterator.next();
while (jobTreeNode)
jobName = jobTreeNode.AOTname();
if ( exportJobName == substr(jobName, 1, 8))
jobTreeNode.treeNodeExport(folderpathJobs + ‘\\Job_’ + jobName + “.xpo”);
noOfJobs++;
CodeAccessPermission::revertAssert();
if (noOfProjects > 0)
info(strfmt(‘%1 Projects exported sucessfully’, noOfProjects));
if (noOfJobs > 0)
info(strfmt(‘%1 Jobs exported sucessfully’, noOfJobs));
Hope this will help you guys.
// Vasanth Arivali
How to find in AOT all objects named like... Blog bot DAX Blogs 0 25.09.2014 01:24
vasantharivali: Using AOT Query Object in X++ Code Blog bot DAX Blogs 0 17.11.2012 11:12
emeadaxsupport: Identifying damaged Table objects in the AOT MetaData Blog bot DAX Blogs 0 16.03.2010 21:05
SysDictCoder: Changing properties of AOT objects in code Blog bot DAX Blogs 0 04.05.2009 20:05
clausba:Running more than one active configuration in BA 4.00 Blog bot Dynamics CRM: Blogs 0 23.05.2005 10:35
Часовой пояс GMT +3, время: 19:55.
