Старый 05.04.2017, 17:11   #1
organicax: Production Order – Operations starting and updating
Источник: https://organicax.com/2017/04/05/pro...-and-updating/
When you need to start and report feedback to production there could be many different ways you might need to do that based on how you operate. It might be that a manager collects feedback and updates the system. It might be that you don’t often have issues or need to record detailed time so you accept the defaults setup for material and time consumption. AX allows you do vary the processes based on how you work.
In this example let’s have a look at a few ways to start and update production, in this example using operations and not tracking down to the job on a production order.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
dynamicsaxse: February release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 02.03.2017 01:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
wiki.dynamicsbook: Changes Made in Navision Attain 301 Blog bot Dynamics CRM: Blogs 0 19.08.2008 13:44
Часовой пояс GMT +3, время: 01:13.
