Старый 27.10.2017, 10:11   #1
dynamicsnavax: Chain of Command–next() gotcha
Источник: http://dynamicsnavax.blogspot.com/20...xt-gotcha.html
Be careful when using Chain of Command not to place the next() call in a condition.
Here is an example.
Create a class extension for a form. Call the method init() but place it in an “if” condition. Something like this.
public void init()
if (this.args() && this.args().record())
//do something before
next init(); //this is inside the “if” condition
//do something after
The compiler will not error or give you a warning. However, at run time you will get a misleading error.
In my case I got this. “Error executing code: Wrong argument type for function.”
Having a look at Event viewer (Folder: AX-XppRuntime), it gave me a little more info. At least I know the class that was calling it. I searched for any customization.
I found an extension class PurchReqCreate_Extension. I was able to eye ball and figure out the problem. Taking next() outside the “if” condition.
Rewrote the same:
public void init()
do something before
} next init();
do something after
stoneridgesoftware: Using the new Chain of Command feature in X++ Blog bot DAX Blogs 0 29.09.2017 07:11
dynamicsnavax: Hybrid connection - Web Api App for AX 2012 to Azure-part 4 Blog bot DAX Blogs 0 14.09.2017 13:11
axmfg: Supply chain excellence in manufacturing Blog bot DAX Blogs 0 01.11.2013 01:11
Часовой пояс GMT +3, время: 11:17.
