Старый 08.11.2017, 18:11   #1
palleagermark: XQuery to save source code from all tables and classes
Источник: http://www.agermark.com/2017/11/blog-post.html
You can use this XQuery, with for example BaseX, to save all your source code from table and classes to an XML file:
for $t in AxClass | AxTable
order by $t/local-name(.), $t/Name ascending
for $y in ($t/SourceCode/Methods/Method)
return
source code
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
ax_gfm_framework_team: Step 2: Perform initial wiring to Source Document Framework – tables and maps Blog bot DAX Blogs 0 28.04.2012 10:11
Передача функции в качестве параметра lemchey_white DAX: Программирование 20 21.01.2008 22:51
Часовой пояс GMT +3, время: 08:53.
