Старый 26.12.2017, 14:11   #1
alirazazaidi: Process upload jobs encountered ProcessSourceRequestHeaderException Dynamics Ax 2012 R3.
Источник: https://www.tech.alirazazaidi.com/pr...cs-ax-2012-r3/
After completing VAT patch in Dynamics Ax 2012 R3, We got error in Retail Process job.
Process upload jobs encountered ProcessSourceRequestHeaderException. Error Details: Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.ProcessSourceRequestHeaderException: ProcessSourceRequestHeader failed to execute all delete requests —> Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.ProcessReadRequestsException: Read request num: 1 on table:[ax].[RETAILFISCALDOCUMENT_BR] failed to execute. —> Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.RunException: Query: SELECT [ACCESSKEY],[AUTHORITYCODE],[CHANNEL],[CONSUMEREFDOCINQUIRYURL],[CONTINGENCYDATETIME],[CONTING FROM [ax].[RETAILFISCALDOCUMENT_BR] WHERE [ReplicationCounterFromOrigin]>@__scSqlFilterParam0 AND [ReplicationCounterFromOrigin] System.Data.SqlClient.SqlException: Invalid column name ‘EFRREGISTERNUMBER’.
Invalid column name ‘FISCALESTABLISHMENTTRADENAME’.
Invalid column name ‘ORIGINALDISCOUNTAMOUNT’.
Invalid column name ‘SENDBYEMAIL’.
Invalid column name ‘SOFTWAREHOUSECNPJ’.
Invalid column name ‘TAXAUTHORITYINFO’.
Invalid column name ‘THIRDPARTYFORMATTEDADDRESS’.
Invalid column name ‘THIRDPARTYICMSCONTRIBUTOR’.
Invalid column name ‘THIRDPARTYIE’
Yes one thing is clear that some fields in missing In Retail store database. On opening in AX, The same table has more fields then retail store db, these fields came with Patch. Some Sync problem.  So I have to follow these steps to complete the sync
Retails==> setup ==> Scheduler subjobs.
Scheduler Sub jobs select the required table and click on Transfer folder list
Functions => mapping.
Click on Yes
Run the process job, error is gone.
alirazazaidi: Team Explorer for Microsoft Visual Studio 2012 not found for Code merge Dynamics Ax 2012 R3 apply update Blog bot DAX Blogs 0 19.12.2017 12:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 17 Blog bot Dynamics CRM: Blogs 0 10.05.2014 06:30
DAX: A Shift to Effective Demand Forecasting With Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 16.11.2013 02:13
Часовой пояс GMT +3, время: 06:19.
