Старый 08.01.2018, 18:14   #1
Afna CRM: Get CRM Reports statistics
Источник: http://a-crm.blogspot.com/2018/01/ge...tatistics.html
If you want to see how may times a certain report has been executed, run this query on the ReportServer database. First replace the [CRM DATABASE NAME_MSCRM] with the correct CRM database name. If the database is not on the same server, then you can't simply joint the tables in one query, but still you can get the report Id list from the Reps (Name column).
;WITH Reps AS
SELECT c.Name,
c.[Path],
COUNT(*) AS TimesRun,
MAX(l.TimeStart) AS [LastRun]
FROM [ReportServer].[dbo].[ExecutionLog](NOLOCK) AS l
INNER JOIN [ReportServer].[dbo].[Catalog](NOLOCK) AS c ON l.ReportID = C.ItemID
WHERE c.Type = 2 -- Only show reports 1=folder, 2=Report, 3=Resource, 4=Linked Report, 5=Data Source
GROUP BY l.ReportId,
c.Name,
c.[Path]
SELECT CRM.Name, CRM.ReportId, Reps.TimesRun, Reps.LastRun, Reps.Path FROM Reps JOIN [CRM DATABASE NAME_MSCRM]..Report CRM ON Reps.Name = '{' + CAST(CRM.reportid AS CHAR(36)) + '}'
Be aware that the statistic is there for a limited time. Execute this to get the minimum date: SELECT MIN(ExecutionLog.TimeStart) FROM [ReportServer].[dbo].ExecutionLog
Microsoft Dynamics CRM Team Blog: Personalizing Reports for Microsoft Dynamics CRM Online Blog bot Dynamics CRM: Blogs 0 21.12.2011 08:11
crminthefield: CRM 2011 Error “Scheduling reports on behalf of other users is prohibitted” when scheduling reports Blog bot Dynamics CRM: Blogs 0 21.12.2011 01:16
Microsoft Dynamics CRM Team Blog: Update Rollup 5 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 2 27.10.2011 17:11
Rahul Sharma: Microsoft Dynamics CRM 2011 Fetch XML based Custom Reports Blog bot Dynamics CRM: Blogs 0 15.04.2011 00:12
Все о Microsoft Dynamics CRM: Как установить Microsoft Dynamics CRM 2011 Beta Blog bot Dynamics CRM: Blogs 0 31.10.2010 15:08
Часовой пояс GMT +3, время: 00:09.
