Старый 19.01.2018, 06:11   #1
crmtipoftheday: Tip #1057: Voice of the Customer says “Don’t change your URL”
Источник: https://crmtipoftheday.com/1057/voic...ange-your-url/
Jerry Weinstock found out the hard way that if you change your Dynamics 365 instance URL after you install Voice of the Customer, survey responses will not synchronize with Dynamics 365. Survey responses will still be captured in Azure, but they will not appear in Dynamics 365.
  • If you want to change your URL, do it before you install Voice of the Customer
  • If you have already installed Voice of the Customer, contact Dynamics 365 support.
crmtipoftheday: Tip #1042: New trial sign up options for Customer Engagement Blog bot Dynamics CRM: Blogs 0 13.12.2017 12:11
crmtipoftheday: Tip #1035: HTML codes in Voice of the Customer Blog bot Dynamics CRM: Blogs 0 01.12.2017 05:17
stoneridgesoftware: Changes to Microsoft Dynamics NAV Change Log System: How to Revert its Behavior Blog bot NAV: Blogs 0 23.06.2016 20:13
Microsoft Dynamics CRM Team Blog: Preview feature: Voice of the Customer surveys Blog bot Dynamics CRM: Blogs 0 13.01.2016 22:11
Часовой пояс GMT +3, время: 16:18.
