Старый 27.02.2018, 02:13   #1
sinedax: Synchronize the database manually - Dynamics 365 for Finance & Operations On Premises Installation
Источник: http://sinedax.blogspot.com/2018/02/...-dynamics.html
Hi All
Sometime in a D365FO On Premise deployment the Sync doesn't triggered!
What to do?
You can run the Database Sync manually as per the "Copy a Finance and Operations database from SQL Server to a production Azure SQL Database environment" procedure.
In an On Premise change a little bit.
The steps are:
  • Connect to RDP to an AOS Node
  • Open the PowerShell ISE
  • Copy the script below and change the Bold part as per your environment
  • In that case my package name is "K"
cd C:\ProgramData\SF\AOS_XX\Fabric\work\Applications\AXSFType_App164\AXSF.Code.1.0.0.20171212_K.zip.0\Packages\bin
.\Microsoft.Dynamics.AX.Deployment.Setup.exe -bindir "C:\ProgramData\SF\AOS_3\Fabric\work\Applications\AXSFType_App164\AXSF.Code.1.0.0.20171212_K.zip.0\Packages" -metadatadir "C:\ProgramData\SF\AOS_3\Fabric\work\Applications\AXSFType_App164\AXSF.Code.1.0.0.20171212_K.zip.0\Packages" -sqluser "axdbadmin" -sqlserver "FQDN SQL instance" -sqldatabase "axdb" -setupmode "sync" -syncmode "fullall" -isazuresql "false" -sqlpwd "password"
Enjoy with D365FO On Premise!
emeadaxsupport: Dynamics 365 for Finance and Operations – Requesting a ‘Database refresh’ – Enable user access Blog bot DAX Blogs 0 29.08.2017 19:11
NAV Team: Upgrading from Microsoft Dynamics NAV 2009 R2 or Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 23.02.2015 13:00
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
Часовой пояс GMT +3, время: 16:32.
