Старый 08.08.2018, 14:11   #1
d365technext: Class Extension D365FO
Источник: http://d365technext.blogspot.com/201...on-d365fo.html
In this blog I will show you class extension in D365 and add new method in the existing class without any over-layer..
There are two way to create Extension of the existing class...
  1. Static Class
  2. ExtensionOf
Static class
Create a new public static class use the name pattern ClassName + _Extension
You can use the following code for reference....
publicstaticclassSLD_PaymFee_Extension
publicstaticvoid paymfeeFind(PaymFee _this)
/// You can write your code here
_this.findFees(); //Use _this to call methods from the base class;
ExtensionOf
Create new class add the annotation of ExtensionOf and enter the class name... In this type of extension add final keyword.
[ExtensionOf(classStr(PaymFee))]
finalclass SLD_PaymFee_Extension
For verification you can use the below code
classSLD_DemoClass
publicstaticvoid main(Args _args)
PaymFee obj =new PaymFee();
obj.paymfeeFind();
d365technext: Label Extension D365FO Blog bot DAX Blogs 0 07.08.2018 19:11
d365technext: FormHasMethod extension in D365FO Blog bot DAX Blogs 0 03.08.2018 18:11
d365technext: Private, Protected and Public attribute access in Class Extension Blog bot DAX Blogs 0 30.07.2018 20:13
goshoom: Class extensions Blog bot DAX Blogs 0 18.07.2016 17:11
german_nav_developer: Codepage und Multilinguale Dynamics NAV Installationen Blog bot Dynamics CRM: Blogs 0 05.06.2011 15:51
Часовой пояс GMT +3, время: 03:05.
