#1 |
alirazazaidi: Table method extension and grid field mapping Dynamics 365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/ta...nd-operations/
============== Hi all, here is small tip, I learned today, so document it I need a custom method in table extension. And then this method need to call in field mapping inside Grid. Interesting it is amazing easy. So like other extensions. You have to create a class add a attribute and make in static class show it will extension of certain table. And now create a method Suppose I need extension for PurchRFQScoring table [ExtensionOf(tableStr(PurchRFQScoring))]Now compile solution. And open the grid and from field mapping, set table In source. And in field you have to add method with class reference like PurchRFQScoring_Extension::ScoringName ![]() Источник: https://www.tech.alirazazaidi.com/ta...nd-operations/
