Старый 24.01.2019, 20:11   #1
erconsult: On the AXSCDPPKG file structure
Источник: http://erconsult.eu/blog/axscdppkg/
Application hotfixes for Dynamics 365 for Finance and Operations are distributed via AXSCDPPKG (AX Source Code Deployable Package) files. They can be downloaded from the LCS Issue Search page. The deployment process with the help of the SCDPBundleInstall.exe utility as described in this working instruction.
However, prior to the installation you may want to quickly review the code to check if this is what you are looking for. The LCS Metadata hotfix is nothing but a set of 3+ nested ZIP files, quickly recognizable by the “PK” magic bytes in the header:
ol { list-style-type: decimal; list-style-position: inside;}li { margin: 20px 0;}
  1. Unpack the MicrosoftDynamicsAX_KBxxxxxxx.zip file as downloaded from the LCS.
  2. Rename the HotfixPackageBundle.axscdppkg file into a ZIP, unpack it. There are at least 2 files inside: one or many (for cumulative hotfixes) nested DynamicsAX_xxxxxxx.axscdp files, and a diagram with their dependencies PackageDependencies.dgml. The dependencies are well described by Mr. de Cavalon in his blog.
  3. Rename, unpack the nested DynamicsAX_xxxxxxx.axscdp. There is a set of application folders (Deltas) with a list of all affected application objects in PackageManifest.xml.
  4. Traverse the Deltas folder to the bottom. There is an XML file like this with the source code before the update ( … ) and after ( … ) in a human readable form, as maintained by the TFS source code versioning system.
The post On the AXSCDPPKG file structure appeared first on ER-Consult.
d365fo, hotfix
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Часовой пояс GMT +3, время: 07:49.
