Старый 29.03.2019, 01:22   #1
Kashperuk Ivan: [Heads up] Explicit dependency required for enabling Process Guide based flows in Warehouse Mobile App
Источник: http://kashperuk.blogspot.com/2019/0...-required.html
Introduction With release of version 8.1.3 (build numbers going as 8.1.227.xxxx), we introduced an additional configuration option on the Mobile device menu items, which controls whether or not the system will attempt using the Process Guide framework for executing a mobile flow This is a temporary configuration option, and is supposed to serve two purposes: Allow having a partially
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Kashperuk Ivan: Warehouse Mobile Devices Portal - Now as an App for your mobile device Blog bot DAX Blogs 0 19.01.2017 14:11
Kashperuk Ivan: Configuration tip: Warehouse mobile devices portal Native application in Azure Active Directory Blog bot DAX Blogs 0 28.12.2016 16:11
Kashperuk Ivan: Tutorial: Custom work types and shipment notes on the mobile device in Warehouse management module in Dynamics AX 2012 R3 Blog bot DAX Blogs 0 01.07.2015 19:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
Часовой пояс GMT +3, время: 14:43.
