Старый 21.01.2020, 11:11   #1
ariste.info: Add multi selection lookup to a SysOperation Framework dialog
Источник: https://ariste.info/en/2020/01/add-m...mework-dialog/
First 2020 post! Happy new year! Yes, I know it’s already past mid January… When you add a field to a SysOperation Framework Data Contract the lookup that the framework creates (if the EDT has a lookup) is a simple, single select lookup. Let’s see how to create a multi select lookup in MSDyn365FO. The … Continue reading Add multi selection lookup to a SysOperation Framework dialog →
The post Add multi selection lookup to a SysOperation Framework dialog was first published in ariste.info.
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
Navigate Into Success: Deploying control add-ins during development in NAV 2016 Blog bot Dynamics CRM: Blogs 0 13.11.2015 10:00
Microsoft Dynamics CRM Team Blog: What’s new in Lookup with CRM 2013: Inline Multi Party Lookup Blog bot Dynamics CRM: Blogs 0 19.11.2013 06:12
ax_gfm_framework_team: Step 4: Add Source Document Framework forms to your document UI Blog bot DAX Blogs 0 04.05.2012 01:11
Axilicious:Business Operation Framework and multi-threading Blog bot DAX Blogs 0 25.02.2012 05:42
Часовой пояс GMT +3, время: 04:23.
