Старый 28.01.2020, 11:11   #1
ariste.info: Calling the LCS Database Movement API in your Azure DevOps pipeline
Источник: https://ariste.info/en/2020/01/calli...vops-pipeline/
I talked about the LCS Database Movement API in a post not long ago, and in this one I’ll show how to call the API using PowerShell from your Azure DevOps Pipelines. What for? Basically, automation. Right now the API only allows the refresh from one Microsoft Dynamics 365 for Finance and Operations environment to … Continue reading Calling the LCS Database Movement API in your Azure DevOps pipeline →
The post Calling the LCS Database Movement API in your Azure DevOps pipeline was first published in ariste.info.
ariste.info: Manually deploy Retail packages for Microsoft Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 07.10.2019 16:48
sertandev: Empowering D365 FO service endpoints with Azure API Management service Blog bot DAX Blogs 0 15.05.2019 22:11
dynamicsnavax: Hybrid connection - Web Api App for AX 2012 to Azure-part 4 Blog bot DAX Blogs 0 14.09.2017 13:11
Microsoft Dynamics NAV Database Archive for all Country Versions Blog bot Dynamics CRM: Blogs 0 11.03.2011 18:43
Часовой пояс GMT +3, время: 03:00.
