Старый 21.02.2020, 04:02   #1
How to replace a financial dimension value in D365
Источник: http://alexvoy.blogspot.com/2020/02/...dimension.html
Thanks to Denis Trunin's article, we can easily implement something like this in D365FO.
public static DimensionDefault setValueToDefaultDimension(DimensionDefault _dimensionDefault, RefRecId _dimensionAttributeRecId, DimensionValue _newDimensionValue)
DimensionAttributeValueSetStorage dimStorage;
DimensionDefault newDimensionDefault = _dimensionDefault;
DimensionAttributeValue dimensionAttributeValue;
if (_dimensionAttributeRecId)
dimStorage = DimensionAttributeValueSetStorage::find(_dimensionDefault);
if (_newDimensionValue)
dimensionAttributeValue = DimensionAttributeValue::findByDimensionAttributeAndValue(DimensionAttribute::find(_dimensionAttributeRecId), _newDimensionValue, false, true);
dimStorage.addItem(dimensionAttributeValue);
else
dimStorage.removeDimensionAttribute(_dimensionAttributeRecId);
newDimensionDefault = dimStorage.save();
return newDimensionDefault;
Then, say, we need to replace Department from Operations to Client Services for Ahmed Barnett in USMF.
static void setNewFinDimValueForEmployee(HcmWorkerRecId _worker, CompanyInfoRecId _legalEntity, Name _dimensionName, DimensionValue _dimensionValue)
HcmEmployment hcmEmployment = HcmEmployment::findByWorkerLegalEntity(_worker, _legalEntity);
ttsbegin;
hcmEmployment.selectForUpdate(true);
hcmEmployment.validTimeStateUpdateMode(ValidTimeStateUpdate::Correction);
DimensionDefault newDim = DimensionHelper::setValueToDefaultDimension(hcmEmployment.DefaultDimension, DimensionAttribute::findByName(_dimensionName).RecId, _dimensionValue);
hcmEmployment.DefaultDimension = newDim;
if(hcmEmployment.validateWrite())
hcmEmployment.update();
ttscommit;
Here you go.
public static void main(Args _args)
HcmWorkerRecId _worker = 22565420995; //Ahmed Barnett
CompanyInfoRecId _legalEntity = 22565422580; //USMF
Name _dimensionName = 'Department';
DimensionValue _dimensionValue = '028'; //Currently 026
DimensionHelper::setNewFinDimValueForEmployee(_worker, _legalEntity, _dimensionName, _dimensionValue);
Info(strFmt("Employee fin dim value changed!"));
patrickmouwen: D365 Retail APIs Part III: How to use the Retail APIs from Power Automate (Flow) and Logic App Blog bot DAX Blogs 0 28.01.2020 02:15
patrickmouwen: D365 Retail APIs Part II: How to know exactly what happens inside D365 Retail Blog bot DAX Blogs 0 14.12.2019 01:17
alirazazaidi: Custom financial Dimension shows in lookup D365 for Finance and operations Blog bot DAX Blogs 0 14.09.2017 13:11
fatihdemirci: How to Replace a Financial Dimension in Default Dimensions [Dynamics AX 2012] Blog bot DAX Blogs 0 09.07.2013 19:12
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 19:24.
