Старый 31.03.2020, 11:11   #1
daxrunbase: Number sequence consumption monitoring
Источник: https://www.daxrunbase.com/2020/03/3...on-monitoring/
Once a company has been live for a while and they are doing Business As Usual, they often forget about maintaining one critical area. The system is using Number Sequences as identifiers, for which we have fixed, allocated range of values. Typical example is a general financial journal with a format like JNL18-###### with values [...]
The post Number sequence consumption monitoring appeared first on DAXRunBase.
emeadaxsupport: AX for Retail: Size Barcode setup and creation with number sequence Blog bot DAX Blogs 0 12.02.2015 01:12
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
goshoom: Year in number sequence (AX2012) Blog bot DAX Blogs 0 16.10.2013 16:11
emeadaxsupport: Where is the System ID number sequence used? Will it run out? Blog bot DAX Blogs 0 25.05.2011 00:11
Часовой пояс GMT +3, время: 00:20.
