Старый 29.05.2020, 11:11   #1
dynamicsnavax: Data import/export Business Events
Источник: http://dynamicsnavax.blogspot.com/20...ss-events.html
Sometime last year, I posted about using Business Events with Data Export. The code was shared on Github too.
Now, I have updated to introduce a Data Import Business event. This is helpful for a number of scenarios (specially for integration).
  • Long running jobs - you don’t want to constantly call Odata services to get the status of your execution job
  • Trigger data execution alerts for integration - you could trigger alerts based on failures.
The argument here could be that you could use alert rules to fire a business event. Alerts rules are flexible but I find that I have to use Odata calls to get more information.
To use the Import Business Event, just make sure the Project category is Integration.
The business event will fire when an execution history is created.
The business event looks like this.
Any feedback is welcomed.
dynamicsnavax: Event Based Integration using Business Events and Data Management Framework Blog bot DAX Blogs 0 18.06.2019 10:13
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Microsoft Dynamics CRM Team Blog: Create Sample Data for your Solution Blog bot Dynamics CRM: Blogs 0 01.12.2011 05:14
Часовой пояс GMT +3, время: 00:20.
