Старый 01.07.2020, 06:11   #1
25,644 / 848 (80) +++++++
crmtipoftheday: Tip #1373: Dynamics 365 Mobile, Quick Create, and form issues
Источник: https://crmtipoftheday.com/1373/dyna...nd-form-issues
You create a model-driven app and open it in the Dynamics 365 mobile app or the Power Apps app (now supports model-driven). But when you click new record, you get a form but you cannot enter in data correctly — maybe there are some missing fields or something else is wrong.
Dynamics 365 mobile uses Quick Create to create records. If you don’t have quick create enabled or a quick create form created for the entity, Dynamics 365 will generate one for you based on the main form.
To quote the official documentation:
Dynamics 365 mobile apps use quick create forms for creating new records. If an entity already has a quick create form configured for it, the mobile apps use that form. If an entity doesn’t have a configured quick create form, Power Apps generates a quick create form for creating records in the mobile apps based on the main form definition.
https://docs.microsoft.com/powerapps/maker/model-driven-apps/create-edit-quick-create-forms
So if you don’t get the expected results, enable quick create on the entity and create a quick create form that contains the desired fields.
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Часовой пояс GMT +3, время: 19:45.
