Старый 30.07.2020, 04:40   #1
How to get a list of the Tables maintained by Change Tracking in SQL
Источник: http://alexvoy.blogspot.com/2020/07/...tained-by.html
Thanks to Brent Ozar and Dave Phillips who showed us how to get a list of the Tables maintained by Change Tracking directly in MS SQL Server Management Studio. It works for both AX2012 and D365 versions.
SET TRANSACTION ISOLATION LEVEL READ UNCOMMITTED;
GO
SELECT
sct1.name AS CT_schema,
sot1.name AS CT_table,
ps1.row_count AS CT_rows,
ps1.reserved_page_count*8./1024. AS CT_reserved_MB,
sct2.name AS tracked_schema,
sot2.name AS tracked_name,
ps2.row_count AS tracked_rows,
ps2.reserved_page_count*8./1024. AS tracked_base_table_MB,
change_tracking_min_valid_version(sot2.object_id) AS min_valid_version
FROM sys.internal_tables it
JOIN sys.objects sot1 ON it.object_id=sot1.object_id
JOIN sys.schemas AS sct1 ON sot1.schema_id=sct1.schema_id
JOIN sys.dm_db_partition_stats ps1 ON it.object_id = ps1. object_id AND ps1.index_id in (0,1)
LEFT JOIN sys.objects sot2 ON it.parent_object_id=sot2.object_id
LEFT JOIN sys.schemas AS sct2 ON sot2.schema_id=sct2.schema_id
LEFT JOIN sys.dm_db_partition_stats ps2 ON sot2.object_id = ps2. object_id AND ps2.index_id in (0,1)
WHERE it.internal_type IN (209, 210)
order by tracked_name
GO
a33ik: How to get list of private projects in the model Blog bot DAX Blogs 0 02.11.2018 20:11
ievgensaxblog: D365FOE. Get list of installed metadata hotfixes using Metadata API. Blog bot DAX Blogs 0 18.11.2017 03:51
emeadaxsupport: How to get the Production Picking list to Use the delivery note layout Blog bot DAX Blogs 0 13.03.2015 22:13
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1A [Introduction and SQL Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Microsoft Dynamics CRM Team Blog: How To: Configure Tracing for Microsoft Dynamics CRM List Component for Microsoft SharePoint Server 2010 Blog bot Dynamics CRM: Blogs 0 21.12.2010 23:12
Часовой пояс GMT +3, время: 15:38.
