Старый 28.10.2020, 23:12   #1
Kashperuk Ivan: [Tool] Display contents of an X++ container from SQL database field
Источник: http://kashperuk.blogspot.com/2020/1...container.html
Almost 15 years ago AndyD from AxForum blew me away with a post that was giving a glimpse into how the X++ containers are stored in the database. Ever since then I had a TODO for myself to write a blog post explaining this in detail and covering the various types that can be stored, basically allowing to review the contents of the container from DB without writing X++ code.Luckily, today is the
Старый 29.10.2020, 12:23   #2
может лучше не на OneDrive выложить,
а на GutHub в раздел Gist?
https://gist.github.com/
За это сообщение автора поблагодарили: trud (2).
Старый 21.11.2020, 19:15   #3
А что за раздел Gist?
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
Kashperuk Ivan: Tutorial: Caching display methods Blog bot DAX Blogs 3 29.09.2015 22:07
hariprasadp: Code for pulling data from other than AX Database of SQL to AX Table Blog bot DAX Blogs 0 16.12.2009 12:05
Nav developer: Basic SQL - Overview of NAV specific SQL features for application consultants Blog bot Dynamics CRM: Blogs 0 05.11.2008 11:52
dynamicsusers: Blocks & Deadlocks in NAV with SQL Server Blog bot Dynamics CRM: Blogs 0 18.04.2008 10:23
Часовой пояс GMT +3, время: 07:48.
