Старый 19.05.2021, 23:11   #1
powerobjects: Authentication to Dynamics 365 using Azure Function v3 (.NET core)
Источник: https://powerobjects.com/dynamics-36...n-v3-net-core/
There are not many examples of trying to use Azure Function v3 (.NET core) to access Dynamics 365. If you find yourself trying to convert the Azure Function v1 (.NET Framework) to v3 (.NET core), you will be better off creating a new Azure Function. And if you’re trying to access Dataverse using the same libraries to access Dataverse in v3 (.NET core) that you were using in v1 (.NET Framework)...
Source
powerobjects: Embedded Intelligence with Email Engagement in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 03.11.2018 02:20
powerobjects: Dynamics 365 Spring 2018 Update: Introducing D365 for Marketing Blog bot Dynamics CRM: Blogs 0 06.06.2018 01:32
powerobjects: What is the Learning Path for Dynamics 365? Blog bot Dynamics CRM: Blogs 0 10.04.2018 01:27
dynamics-coe: Integrating Microsoft Dynamics CRM 2011 Online with Java and other non-.Net Clients Blog bot Dynamics CRM: Blogs 0 21.09.2013 13:11
Часовой пояс GMT +3, время: 04:19.
