Старый 25.05.2021, 15:11   #1
25,644 / 848 (80) +++++++
dynamicsaxinsight: Write TSV file in X++
Источник: https://dynamicsaxinsight.wordpress....v-file-in-xpp/
Purpose:
The purpose of this blog post is to demonstrate how can we write a tsv (tab delimited) file in X++
  • The code actually exports system database log to a TSV file
  • Uses standard SysDatabaseLogReport query
  • Adds a range for Warehouse table
  • Uses formatted datetime string for filename
Product:
Dynamics AX 2012
Code:
Class declaration.
class MAKSysDatabaseLogService{ #File #define.EmptyString('') FileIOPermission IOPermission; SysDataBaseLog sysDataBaseLog; container cont; TextIo file; FieldName fieldNameText; str oldValueText; str newValueText;}
Run method. The main method of the class.
public void run(){ container tmp; Query query; QueryBuildDataSource qbds; QueryRun queryRun; List list; ListEnumerator enumerator; fieldId fieldId; str fileName; boolean written; System.DateTime dateTime; str dateTimeStr; ; dateTime = System.DateTime::get_Now(); dateTimeStr = dateTime.ToString('yyyyMMddHHmmss'); query = new query(queryStr(SysDatabaseLogReport)); qbds = query.dataSourceTable(tableNum(SysDatabaseLog)); qbds.addRange(fieldNum(SysDatabaseLog, Table)).value("158"); // Table Warehouse queryRun = new QueryRun(query); try { fileName = strFmt("%1\\Databaselog_%2.csv", ICH_DatabaseLogSetup::find().FilePath, dateTimeStr); IOPermission = new FileIOPermission(fileName, #IO_WRITE); IOPermission.assert(); file = new TextIo(filename, #IO_WRITE); file.outRecordDelimiter(#delimiterCRLF); file.outFieldDelimiter("\t"); this.writeHeader(); while (queryRun.next()) { sysDataBaseLog = queryRun.get(tablenum(SysDataBaseLog)); fieldNameText = #EmptyString; newvalueText = #EmptyString; oldValueText = #EmptyString; written = false; list = sysDataBaseLog.getDataAslist(); enumerator = list.getEnumerator(); while (enumerator.moveNext()) { tmp = enumerator.current(); fieldId = conpeek(tmp, 1); fieldNameText = fieldid2pname(sysDataBaseLog.Table, fieldId); newValueText = sysDataBaseLog.contents2Str(conpeek(tmp, 2), fieldId); oldValueText = sysDataBaseLog.contents2Str(conpeek(tmp, 3), fieldId); this.writeLine(); written = true; } if (!written) { this.writeLine(); } } info(strFmt("%1", "Database log exported successfully.")); } catch(Exception::Error) { error("ERROR"); } CodeAccessPermission::revertAssert();}
Writes header to the file.
private void writeHeader(){ cont = connull(); cont = conins(cont, 1, "Table name"); cont = conins(cont, 2, "Description"); cont = conins(cont, 3, "Log type"); cont = conins(cont, 4, "Created by"); cont = conins(cont, 5, "Field name"); cont = conins(cont, 6, "Value"); cont = conins(cont, 7, "Previous value"); cont = conins(cont, 8, "Created date and time"); file.writeExp(cont);}
Writes a line to the file.
private void writeLine(){ cont = connull(); cont = conins(cont, 1, sysDataBaseLog.tableName()); cont = conins(cont, 2, sysDataBaseLog.Description); cont = conins(cont, 3, sysDataBaseLog.LogType); cont = conins(cont, 4, sysDataBaseLog.createdBy); cont = conins(cont, 5, fieldNameText); cont = conins(cont, 6, newValueText); cont = conins(cont, 7, oldValueText); cont = conins(cont, 8, sysDataBaseLog.createdDateTime); file.writeExp(cont);}
dynamicsaxinsight: Read CSV file in X++ Blog bot DAX Blogs 0 20.10.2020 14:12
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Часовой пояс GMT +3, время: 22:42.
