Старый 27.05.2021, 00:13   #1
butenko.pro: Plugin: How to fix “The ‘Accept’ header must be modified using the appropriate property or method. Parameter name: name” error
Источник: https://butenko.pro/2021/05/26/plugi...me-name-error/
I was working on the integration between Dataverse and external Rest API. The scenario is simple as – “Send the JSON object to the API when the record is created”. In order to implement this, I decided to develop the plugin that will get the data from the context, transform it to the proper JSON ...
mohsinkhalid: #D365 Solution: The property ‘ComputedFieldMethod’ must be set with the name of a valid data entity method if ‘IsComputedField’ is set to ‘Yes’. Blog bot DAX Blogs 0 21.03.2018 21:11
a33ik: MS CRM 2013: How to fix ‘sdkmessage With Id = {} Does Not Exist’ error Blog bot Dynamics CRM: Blogs 0 22.01.2014 09:11
emeadaxsupport: "Parameter is missing a value" error running a customized report in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 21.11.2012 00:12
daxline: How to fix - The server-side impersonated (RunAs) session tried to invoke a method that is available for client-side processing only Blog bot DAX Blogs 0 28.06.2011 19:11
Часовой пояс GMT +3, время: 12:49.
