Старый 18.08.2021, 17:11   #1
d365technext: The 'Dimension Legal Entity Context field' must be entered
Источник: http://d365technext.blogspot.com/202...y-context.html
The 'Dimension Legal Entity Context field' must be entered, when the extended data type is 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount'.
Today, I was getting the following errors while creating one data entity, after searching over google I realized that two field-level properties on my entity should be filled.
  • DimensionLegalEntityContextField
  • DynamicDimensionEnumerationField
Path: [AxDataEntityView/ABCDEntity/Fields/LedgerDimension/DimensionLegalEntityContextField]:The 'Dimension Legal Entity Context field' must be entered, when the extended data type is 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount'.Path: [AxDataEntityView/ABCDEntity/Fields/LedgerDimension/DynamicDimensionEnumerationField]:The 'Dynamic Dimension Enumeration Field' must be entered, when the extended data type is 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount'.
Solution
This field property should be filled with Data Area Id, for reference, I also pasted the screenshot.
This field property should be filled with either 'DimensionDynamicAccount' or 'DimensionDynamicDefaultAccount for reference, I also pasted the screenshot.
Options:
  1. DimensionDynamicAccount
  2. DimensionDynamicDefaultAccount
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
german_nav_developer: Upgrade Tips & Tricks Teil 3 Blog bot NAV: Blogs 0 17.03.2017 13:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 11:51.
