Старый 29.08.2021, 05:36   #1
d365technext: D365FO Batch Job retries
Источник: http://d365technext.blogspot.com/202...b-retries.html
Enable automatic retries on batch jobs
In the April/May released, Microsoft introduces the feature to retry the batch job, In the past, if the Finance and Operations apps experience any kind of loss of connection to Microsoft SQL Server, then all batch jobs that are running fail, and the reason is, on Azure if the connection is lost then the recovery is almost impossible.
So, Microsoft introduces an Interface class that will batch to reset itself in case of connection loss or failure.
How you can implement it in your code?
Here is an example if you are using the "RunBaseBatch" class in your batch Job.
class TestBatchJob extends RunBaseBatch implements BatchRetryable
[Wrappable(true), Replaceable(true)] // Change to meet your customizability requirements
public boolean isRetryable() // Use final if you want to prevent overriding
return true;
Here is an example if you are using the "SysOperationServiceController" class in your batch Job.
class TestBatchJob extends SysOperationServiceController implements BatchRetryable
return true;
Important
If you designing a multithreading job and adding the runtime task, then you should implement this interface on both the main controller and the task controller.
If you want to disable the retry of the batch job then add your class in the
Batch class configuration overrides
Overrides setup
d365technext: How to disable/hide report/Batch Job parameter on Dialogue Blog bot DAX Blogs 0 27.08.2021 20:15
kurthatlevik: Batch Jobs; Take control of the executions Blog bot DAX Blogs 0 20.01.2020 20:13
d365technext: Batch job Execution for ALL Companies Blog bot DAX Blogs 0 02.08.2018 01:40
d365technext: Batch Multi threading D365FO AX7 Blog bot DAX Blogs 0 31.07.2018 23:16
Часовой пояс GMT +3, время: 22:21.
