Старый 05.01.2022, 13:14   #1
a33ik: Override form control Lookup using extensions
Источник: http://daxonline.org/1740-override-f...xtensions.html
Expand controll Events node and right click on OnLookup and select Copy event handlr method.
To supress standard lookup method and following warning message:
More than one form was opened at once for the lookup control.
Use following code:
FormControlCancelableSuperEventArgs ce = e as FormControlCancelableSuperEventArgs; ce.CancelSuperCall();
Full lookup method:
[FormControlEventHandler(formControlStr(AssetParameters, VKInterfacesGroup_VKFixedAssetJournalNameId), FormControlEventType::Lookup)] public static void VKInterfacesGroup_VKFixedAssetJournalNameId_OnLookup(FormControl sender, FormControlEventArgs e) { Query query = new Query(); QueryBuildDataSource queryBuildDataSource; QueryBuildRange queryBuildRange; SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(InventJournalName), sender); sysTableLookup.addLookupField(fieldNum(InventJournalName, JournalNameId)); sysTableLookup.addLookupField(fieldNum(InventJournalName, Description)); queryBuildDataSource = query.addDataSource(tableNum(InventJournalName)); queryBuildRange = queryBuildDataSource.addRange(fieldNum(InventJournalName, JournalType)); queryBuildRange.value(SysQuery::value(InventJournalType::Asset)); sysTableLookup.parmQuery(query); sysTableLookup.performFormLookup(); FormControlCancelableSuperEventArgs ce = e as FormControlCancelableSuperEventArgs; ce.CancelSuperCall(); }
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 02:12.
