Старый 13.03.2023, 16:11   #1
25,644 / 848 (80) +++++++
d365fokartik: DMT –  Use the Data migration tool to migrate from Dynamics AX 2009 to finance and operations – Part 2
Источник: https://d365fokartik.home.blog/2023/...ations-part-2/
Please note the file is saved as .xlsx. Please save as .xlsx and do not change the extension. When you give this as an input to the Default Configuration parameter value in the next step, select All Files to select .xlsx file. Failure to follow this step will cause downstream errors during generate mappings. 2. […]
msdynamicsworld: From the Microsoft Dynamics 365 Finance & Operations Blogs: Data lakes; Custom objects; Customer holds; Restore security Blog bot DAX Blogs 0 25.12.2021 03:58
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
stoneridgesoftware: The Four Steps to Upgrade from Dynamics AX to Dynamics 365 Finance and Operations Blog bot DAX Blogs 0 12.02.2019 19:11
stoneridgesoftware: Why You Should Consider Upgrading from Dynamics AX to Dynamics 365 Finance and Operations Blog bot DAX Blogs 0 05.02.2019 18:11
Часовой пояс GMT +3, время: 08:43.
