#1 |
sunilrakesh: How to get x++ methods as Microsoft Flow- Action. Example for Submit & Recall workflow. D365FO
Источник: https://community.dynamics.com/ax/b/...orkflow-d365fo
============== Here is an example on how to create Flow action for x++ methods. I have an requirement from Flow a record(Purchase requisition) want to submit/ Recall workflow. Below steps explain the process. 1. Create custom Data entity. 2. Add new method as shown for SUBMIT. [SysODataActionAttribute("GetAzureSubmitl", false)] public static str GetAzureSubmitl(PurchReqId purchReqId ) { WorkflowVersionTable workflowVersionTable; PurchReqTable _purchReqTable; boolean submited = true; PurchReqWorkflow purchReqWF; select _purchReqTable where _purchReqTable.PurchReqId == purchReqId ; // with parameter value string. workflowVersionTable = Workflow::findWorkflowConfigToActivateForType(workFlowTypeStr(PurchReqReview), _purchReqTable.RecId, _purchReqTable.TableId); if (_purchReqTable.RecId && workflowVersionTable.RecId && _purchReqTable.RequisitionStatus == PurchReqRequisitionStatus::Draft) { if (PurchReqWFStatusTransitionHelper::setPurchReqTable2InReview(_purchReqTable.RecId)) { Workflow::activateFromWorkflowType(workFlowTypeStr(PurchReqReview), _purchReqTable.RecId, "Submitted", NoYes::No, DirPersonUserEx::worker2UserId(_purchReqTable.Originator)); } } else { submited = false; } } 3. Save and build you project, you can see your method as an Action in Flow. sample code for RECALL Purchase requisition workflow. [SysODataActionAttribute("GetAzureRecall", false)] public static str GetAzureRecall(PurchReqId purchReqId ) { Code for RECALL WorkflowCorrelationId workflowCorrelationId; PurchReqTable purchReqTable; boolean recalled = true; select purchReqTable where purchReqTable.PurchReqId == purchReqId;//with parameter value string. if(purchReqTable.RecId != 0 && purchReqTable.RequisitionStatus == PurchReqRequisitionStatus::InReview) { PurchReqWFStatusTransitionHelper::setPurchReqTable2Draft(purchReqTable.RecId); workflowCorrelationId = Workflow::activateFromWorkflowType(workFlowTypeStr(PurchReqReview), purchReqTable.RecId, "Recalled by user", NoYes::No, DirPersonUserEx::worker2UserId(purchReqTable.Originator)); Workflow::cancelWorkflow(workflowCorrelationId,"Recalled by user"); } else { recalled = false; } } Источник: https://community.dynamics.com/ax/b/...orkflow-d365fo
Опции просмотра | |
