Старый 08.02.2007, 22:31   #1
Kashperuk Ivan: AxCreateNewProject version 1.3.1 availableI have...
Источник: http://kashperuk.blogspot.com/2007/0...version-1.html
I have also upgraded the tool for creating new projects to version 1.3.1
The new feature are:
Version 1.3.1
Fixed a small bug I stumbled upon recently: If you temporarily turn off the project prefix that contains a long name, and enter a long name for the project, the validation fails telling that the project name is too long - the CheckBox value is not analyzed.
Version 1.3
Now you can update an existing project adding new project nodes to it. Just select the project you want to update and hold the Ctrl key when calling the AxCreateNewProject tool. This will automatically initialize the Settings Tree with the project group nodes found in the selected project. Also, the warning confirmation message won't be shown when you press the OK button and the existence of a project with the same name is not considered an error in the image window.
Moreover, you can now selectively duplicate the objects of an existing project together with the project group nodes. In order to do this select an existing project for update and simply input a new name for the project. You will notice that a button Copy Objects will appear in the bottom left corner of the dialog window. Pressing this button will add the objects found in the selected project into the Settings Tree and will be copied into the new project as well. You will be able to deselect some of the objects (see Known Issues) if you do not need to carry them over to the new project.
You can download the new version HERE or from the Homepage
Kashperuk Ivan: EditorScripts.addIns_OpenInAOT - version 2 Blog bot DAX Blogs 0 29.05.2008 17:05
Kashperuk Ivan: DEV_SysTableBrowser version 2.0 is out! Blog bot DAX Blogs 20 25.10.2007 21:03
Kashperuk Ivan: DEV_CreateNewProject tool version 2.0.0 Blog bot DAX Blogs 0 04.09.2007 01:12
Kashperuk Ivan: AxCreateNewProject version 1.3.2 releasedUpdated... Blog bot DAX Blogs 0 16.03.2007 22:51
Kashperuk Ivan: AxCreateNewProject tool Version 1.2I made some a... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 18:50.
