Старый 18.07.2007, 16:10   #1
Dynamics AX: What version of SQL Server for a new install?
Источник: http://dynamics-ax.blogspot.com/2007...r-for-new.html
Lets talk about now, which version of SQL Server a new install should be implementing with. Flat out answer, for now, is SQL Server x64 standard edition. Why? Here is a few reason why this is the answer, for Most implementations today:
- The amount of allocated RAM for 32-bit version is only 4 GB max for a given instance, any other RAM can only be used for Data
- Lower TCO because the 64-bit Version can user up to 32 GB of RAM in Standard Edt.
So basically for a little more money than 32-bit Standard Edt, a given new implementation can get the same amount of RAM use as 32-bit Enterprise Edt. for standard cost when using x64 bit Standard edt. If you must use Enterprise Edt. for advanced clustering, online index creation, etc. then go with the 64 bit version, as this can use up to 1 Terabyte of RAM.
Now all implementations are different, maybe hardware will not allow for x64. However if this is a totally new implementation, and new hardware is being bought, then x64 is for sure the route to take from this point forward. What you get out of the RAM and processing is now worth the effort, which is not much anymore, to have your SQL Server system running on x64.
Check back later as I will continue to post about SQL Server performance and Dynamics AX. One thing to point out here is that AWE, like in the post before, is Not required and has no need to be used in x64.
Check back soon!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
За это сообщение автора поблагодарили: SerAl (1).
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
jinx: Microsoft Dynamics AX 2009, Windows Server 2008 und SQL Server 2008 Blog bot DAX auf Deutsch 0 12.10.2008 20:10
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
Часовой пояс GMT +3, время: 17:39.
