Старый 16.01.2008, 15:00   #1
axcoder: Syntax highlighting of X++ code in your blog or site
Источник: http://axcoder.blogspot.com/2008/01/...e-in-your.html
1. Download highlight.js archive
2. Unpack archive and place it on your site
3. Аdd the following lines at start your html
<SPAN class="tag"></SPAN class="keyword"script/SPAN>
<SPAN class="tag">
initHighlightingOnLoad('axapta');
(or, add html/javascript block with that content in the blogger.com template editor. If you use blogger, you should replace path to the script with full path to site where you uploaded the script like "http://belugin.info/highlight.js")
4. Include attach the sample.css stylesheet to your page or add it's contents to the "style" tag of your blogger template
5. Post your code snippets like this:
<SPAN class="tag"><SPAN class="tag">
// your code here
</SPAN class="keyword"code/SPAN></SPAN class="keyword"pre/SPAN>
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
Dynamics AX: Microsoft Dynamics AX EP Team Blog - Filtering a DataSet from Code behind Blog bot DAX Blogs 0 04.12.2008 03:07
Site в складской аналитике. Как лучше перевести? mazzy DAX: Прочие вопросы 73 07.01.2008 12:18
axcoder: Dianne Siebold's blog Blog bot DAX Blogs 0 15.10.2007 15:22
Часовой пояс GMT +3, время: 10:40.
