Старый 28.04.2008, 19:05   #1
gatesasbait: Automatic creation of a PDF from a customer invoice in Dynamics Ax 4.0
Источник: http://gatesasbait.spaces.live.com/B...B9F5!223.entry
Good morning,
The following code snippet will create a PDF from a CustInvoiceJour record, without any user intervention, using only the standard Ax4 EPSendDocument class.
public static void EPSendDocumentTest(Args _args)
    EPSendDocument sendDocument;
    CustInvoiceJour custInvoiceJour;
    Filename filename;
    select firstonly custInvoiceJour;
    filename = WinAPI::getTempPath() +'MyInvoice.pdf';
    sendDocument = new EPSendDocument(custInvoiceJour);
    sendDocument.parmOriginal(true);
    sendDocument.parmFileName(filename);
    // Make document will run the report and send it to a PDF file with
    // the path specified in filename
    sendDocument.makeDocument();
The file should end up in C:\DOCUME~1\***\LOCALS~1\Temp\MyInvoice.pdf on Win32 installations. I found this while looking at EP weblet 'EPDocuGetWeblet'. The EPSendDocument class supports a lot of other standard reports, such as quotations, etc.
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
gatesasbait: Report 'shape' control issues with PDF Printer class in Dynamics AX 4.0 Blog bot DAX Blogs 0 09.09.2008 07:07
Dynamics AX: Dynamics AX project success - Customer Ownership & Expectations Blog bot DAX Blogs 0 07.08.2007 21:10
Часовой пояс GMT +3, время: 09:50.
