Старый 05.07.2008, 06:33   #1
axperf: Debugging X++ Object Leaks
Источник: http://blogs.msdn.com/axperf/archive...ect-leaks.aspx
One of the most important aspects of writing managed code that interacts with AX through the Business Connector is cleaning up objects. Each AxaptaObject and AxaptaTable must have dispose called on it before going out of scope, or we’ll leak the object...(read more)
Vincent: Debugging business logic in AX 2009 SSRS reports Blog bot DAX Blogs 0 29.11.2008 09:05
Dynamics AX: Map Object Sorting - a real issue Blog bot DAX Blogs 7 15.10.2008 12:02
axStart: A structure way off dealing with garbage collection & memory leaks with the Dynamics AX .net connector. Blog bot DAX Blogs 0 31.07.2008 22:05
SysDictCoder: 10 tips for debugging in Dynamics Ax Blog bot DAX Blogs 0 01.07.2007 22:05
Dynamics AX: .Net BC, C# - Working with AxaptaRecord Object Blog bot DAX Blogs 0 20.06.2007 23:13
Часовой пояс GMT +3, время: 06:03.
