Старый 21.12.2007, 12:30   #1
Holzheys: X++ Transactions, exceptions and updateconflicts.
Источник: http://holzhey.isa-geek.com/blog/pos...conflicts.aspx
In September, I posted an article on x++ transactions unique behaviors. I am following up now with another case where they are even more unique, and where it is an exception to the transaction exception behavior.
In the event that you running under a transaction and in nested try-catch blocks the catch block nearest to a updateconflict exception that catches that exception is allowed to correct that error and continue.
Example code below:
   1:     static void RetrysWithException()
   2:      {
   3:          CustTable custTable;
   4:         int retryCount;
   5:         ;
   6:
   7:
   8:         ttsbegin;
   9:
  10:
  11:
  12:
  13:         select forupdate custTable where custTable.AccountNum == 'S135' && custTable.CustGroup == '00';
  14:         retryCount = 0;
  15:
  16:
  17:
  18:
  19:         try // The ttslevel for this try-catch block is one
  20:         {
  21:                 custTable.CreditRating = strfmt("%1",str2int(custTable.CreditRating)+1);
  22:                 custTable.update(); // The UpdateConflict will be thrown inside this method.
  23:                 info(strfmt("CreditRating = %1", custTable.CreditRating));
  24:         }
  25:         catch (Exception::UpdateConflict)
  26:         {
  27:                 if( retryCount < 4)
  28:                 {
  29:                     retryCount ++;
  30:
  31:
  32:
  33:
  34:                     // reread the row without rolling back the transaction
  35:                     custTable.reread();
  36:                     retry;
  37:                 } else // no more than 5 retries allowed;
  38:                    // may be the business logic requires a try here
  39:                           if (appl.ttslevel() == 0)
  40:                      retry;
  41:                   else
  42:                       throw Exception::UpdateConflict;
  43:                 }
  44:             }
  45:         ttscommit;
  46:      }
Старый 09.10.2008, 23:54   #2
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
Интересное замечание, что UpdateConflict можно обрабатывать ВНУТРИ транзакции, в отличии от всех других видов Exception, которые отлавливаются только за пределами первого блока ttsbegin-ttscommit
Старый 10.10.2008, 01:23   #3
Думаю, нужно уточнить, что первый- не значит самый близкий от места ошибки, а именно первый (ttsLevel == 1)
Часовой пояс GMT +3, время: 06:31.
