		#1 |
			C# and AX Development: How show a popup menu in AX/Axapta
			Источник: http://olondono.blogspot.com/2008/02...-axaxapta.html
			============== In the following sample, I have duplicated the sysAOT form, and I have overrode the context method for the tree control. Here the code to show the system context menu for any selected treeNode. X++: PopupMenu popupMenu; SysContextMenu sysContextMenu; int idx = tree.getFirstSelected(); TreeNode treeNode = tree.getItem(idx).data(); // add some custom menu items int editMenu; int choice; ; // current selected treeNode is valid ? if (treeNode == null) return; // create the SysContextMenu for this TreeNode sysContextMenu = new SysContextMenuTreeNode(treeNode); // System API call to build the popup menu popupMenu = sysContextMenu.buildMenu(this.hWnd()); // Add a custom edit menu popupMenu.insertBreak(); editMenu = popupMenu.insertItem("Edit"); // showing menu choice = popupMenu.draw(); // Showing and processing this popupMenu if (!sysContextMenu.runMenu(choice, sysContextMenu)) { if (choice == editMenu) { SysInfoAction_Editor::newOpen(treeNode.treeNodePath()).run(); } } But, looking in depth, I found that the sysAotFind form can be used to get some practical sample on how we can create our custom popup menu. Here an adapted version of that code to the previous SysAOT2 form(method context within control tree): X++: // current selected treeNode int idx = tree.getFirstSelected(); TreeNode treeNode = tree.getItem(idx).data(); // We want to build, a popup menu, with a custom submenu and another // sysContextMenu as submenu (add-ins menu item) PopupMenu popupMenu = new PopupMenu(this.hWnd()); PopupMenu copyMenu = new PopupMenu(this.hWnd(), popupMenu); PopupMenu subSysContextMenu; SysContextMenu sysContextMenu; // Menu options int open; int editMethod; int copyName; int copyPath; int copyFullPath; int copyAll; int choice; int find; ; // current selected treeNode is valid ? if (treeNode == null) return; // create the SysContextMenu for this TreeNode sysContextMenu = new SysContextMenuTreeNode(treeNode); //--------------------------------- // Building the menu open = popupMenu.insertItem("Open"); popupMenu.insertBreak(); editMethod = popupMenu.insertItem("Edit"); copyName = copyMenu.insertItem("Copy Name"); copyPath = copyMenu.insertItem("Copy Path"); copyFullPath = copyMenu.insertItem("Copy FullPath"); copyAll = copyMenu.insertItem("Copy All"); popupMenu.insertPopupMenu("Copy", copyMenu); popupMenu.insertBreak(); find = popupMenu.insertItem("Find"); popupMenu.insertBreak(); subSysContextMenu = sysContextMenu.buildMenu(this.hWnd(), popupMenu); popupMenu.insertPopupMenu("Add-ins", subSysContextMenu); //--------------------------------- // Now, showing the popup menu choice = popupMenu.draw(); // processing option if (!sysContextMenu.runMenu(choice, sysContextMenu)) { switch (choice) { case open: // to implement break; case editMethod: SysInfoAction_Editor::newOpen(treeNode.treeNodePath()).run(); break; case find: // to implement break; case copyName, copyPath, copyFullPath, copyAll: // to implement break; } } Источник: http://olondono.blogspot.com/2008/02...-axaxapta.html
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
		#2 |
			см. также форму tutorial_PopupMenu
		#3 |
			Также можно посмотреть на реализацию плагинов к Табаксу:
	http://www.axaptapedia.com/DEV_Tabax..._RecentWindows http://www.axaptapedia.com/DEV_Tabax...RecentProjects Там строится контекстное меню, и даже еще и с картинками.  |
		#4 |
			Небольшой комментарий:
	в 4-ой аксапте когда попуп меню строится через PopuMenu класс - сразу теряется стиль меню (Office 2003), а когда вызывется super(handle) - то меню выглядит как надо. Поэтому когда потребовалось добавить свой пункт меню, причём в определённую позицию (PopupMenu.insertItem - на самом деле делает AppendMenu - добавление в конце) пришлось прямо на контроле (StringEdit ячейке Grid) писать: X++: //TE-rko public int showContextMenu(int _menuHandle) { #WinApi #define.filterByLocaLang(100) #define.UserDLL('USER32') int selection; DLL _winApiDLL = new DLL(#UserDLL); DLLFunction _insertMenu = new DLLFunction(_winApiDLL, 'InsertMenuW'); ; _insertMenu.returns(ExtTypes::DWord); _insertMenu.arg(ExtTypes::DWord, ExtTypes::DWord, ExtTypes::DWord, ExtTypes::DWord, ExtTypes::WString); _insertMenu.call(_menuHandle, 2, #MF_BYPOSITION + #MF_STRING, #filterByLocaLang, "Filter by local name"); selection = super(_menuHandle); switch (selection) { case #filterByLocaLang: element.filterByLocalLang(); //моя реакция на меню break; } return selection; }  |
