Старый 19.02.2009, 03:05   #1
XPO file viewer
Источник: http://alexvoy.blogspot.com/2009/02/...le-viewer.html
When you deal with a pile of Axapta project files (xpo-files) it might be very useful to take a look at what it consists of.
For this goal, I created a small application that allows to see the content of an XPO file in Tree view as you got used to see during the import procedure in AX.
No need anymore to load AX, just launch XPOViewer.exe and open the file you want to see. You can also start this application by double-click on files having set it as default system action: by xpo files association.
Loading large project files can take much time, so, be patient and enjoy the progress bar.
In the Tree view you can copy any branch text to your clipboard by Ctrl-C key combination or from the context menu.
axStart: When is my Label file updated in AX? Blog bot DAX Blogs 8 28.01.2010 22:09
XPO file viewer wojzeh DAX: База знаний и проекты 16 04.03.2009 06:19
Ещё книга про Ax на английском - Inside Microsoft Dynamics AX 4.0 StasD DAX: База знаний и проекты 36 22.03.2007 12:51
mfp: Building a layer file from XPO files Blog bot DAX Blogs 0 13.11.2006 22:30
Axapta Lessons: Export a table to a file Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 09:20.
