Старый 24.07.2009, 11:05   #1
Fred Shen: Dynamics AX 2009: Write to eventlog entry
Источник: http://fredshen.spaces.live.com/Blog...E4E3!345.entry
Our client requested to keep track of all Dynamics AX system errors during the User Acceptance Testing. I use the application event logs to store the information.
The following code shows you how to write event log entry with X++:
Create a new class AX_EventLog with a static method WriteEventLog:
static void WriteEventLog(Exception _exception, str _event)
    str eventSource = "AX event";
    str logType = "Application";
    System.Diagnostics.EventLogEntryType eventLogEntryType;
    int eventCategory = 9999;
    switch(_exception)
        case Exception::Info:
            eventLogEntryType = System.Diagnostics.EventLogEntryType::Information;
            break;
        case Exception::Warning:
            eventLogEntryType = System.Diagnostics.EventLogEntryType::Warning;
            break;         default:
            eventLogEntryType = System.Diagnostics.EventLogEntryType::Error;
    if (!System.Diagnostics.EventLog::Exists(eventSource))
        System.Diagnostics.EventLog::CreateEventSource(eventSource, logType);
    System.Diagnostics.EventLog::WriteEntry(eventSource, _event, eventLogEntryType, eventCategory);
In the Info class,
Exception add(
    str _txt,
    str _helpUrl = '',
    SysInfoAction _sysInfoAction = null,
    boolean buildprefix = true)
    AX_EventLog::WriteEventLog(_exception, _txt);
} Here we go, event log entry…
Fred Shen: Dynalink in Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 14.07.2009 15:05
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Часовой пояс GMT +3, время: 12:18.
