Старый 12.09.2009, 17:05   #1
Jim Wang: CRM ISV Add-On : The entry 'ScriptModule' has already been added
Источник: http://jianwang.blogspot.com/2009/09...odule-has.html
I tested a CRM 4.0 add-on (ISV-A) last week, the default ASPX page generated an error:
Parser Error Message: The entry 'ScriptModule' has already been added.
The add-on was located under the folder: CRMWeb\ISV\MyAddon
Of cause it inherits settings from CRM's root web.config: in the CRM's root web.config, the ScriptModule has been added by another ISV's (ISV-B) add-on(it shouldn't do it at all).
But if I remove the ScriptModule from ISV-A's web.config, the error changed to:
Unable to cast object of type 'System.Web.Configuration.ScriptingAuthenticationServiceSection' to type 'System.Web.Configuration.ScriptingAuthenticationServiceSection'.
That's because the .Net version of ScriptModule are different between ISV-A and ISV-B's, so we have to stop ScriptModule(ISV-A's) inheriting from CRM's root web.config.
So that what I need to do on ISV-A's web.config:
Just before the ScriptModule, add a tag, which will remove the inherited setting:
Jim Wang: Customizing CRM by Using the Microsoft Dynamics CRM Developer Toolkit Blog bot Dynamics CRM: Blogs 0 09.04.2009 22:05
Jim Wang: CRM 4.0 External Connector License Blog bot Dynamics CRM: Blogs 0 11.02.2009 06:05
Часовой пояс GMT +3, время: 01:41.
