Старый 27.05.2010, 23:05   #1
Dynamics AX Sustained Engineering: One voucher number only and Transaction Date in Journals
Источник: http://blogs.technet.com/b/dynamicsa...-journals.aspx
When using journals set up as "one voucher number only" and the General Ledger parameter for Check for voucher used: is set to Accept Duplicate the transaction date may not correctly default on journal lines after the intial line. The following code change in \Classes\LedgerJournalEngine\adjustLedgerJournalTrans will address this issue.
if (LedgerParameters::find().CheckVoucher == ReuseVoucher::AcceptDuplicate &&
ledgerJournalTable.ledgerJournalName().NewVoucher == NewVoucher::OneVoucher)
oldTransDate = _ledgerJournalTrans.TransDate;
return;
Часовой пояс GMT +3, время: 20:46.
