Старый 01.07.2010, 03:12   #1
Solutions Monkey: Using EP as a subsite to your existing company intranet portal
Источник: http://blogs.msdn.com/b/solutions/ar...et-portal.aspx
If you already have a SharePoint based intranet portal for your company , you may want to create the Microsoft Dynamics AX Enterprise portal as a sub site to this intranet portal to provide a seamless integrated experience to the users. For EP sub site creation to work, you need to check and make sure the below two are set correctly.
1. The application pool of the IIS Web site running the intranet portal need to use the BC proxy account as the identity
2. In Sub site creation, select the Microsoft Dynamics AX Enterprise Portal Site template and custom tab and also select “Use same permission as the parent site” option for User permissions. ( The SharePoint permission is only the front end gate keeper and actual data visibility and access permission is controlled inside Microsoft Dynamics AX.)
Solutions Monkey: Screencast - How to set up Enterprise Portal (EP) in a Network Load Balancing (NLB) MOSS 2007 cluster Blog bot DAX Blogs 0 14.08.2009 11:05
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 07:47.
