Старый 15.09.2010, 11:05   #1
workflowax: No action bar displayed when accessing from email
Источник: http://workflowax.wordpress.com/2010...ng-from-email/
I recently discovered another weird quirk in workflow relating to jumping directly to a record in AX from an email notification. If you are running in a multi-company environment and the user’s default company is different from the company in which the workflow document resides, the yellow workflow bar will not be displayed when accessing the record directly via the drill-down functionality in workflow notification emails, assuming that there was no already opened AX client. Re-opening the form manually reveals the workflow bar.
It appears that the sequence in which the AX client and user defaults are loaded causes the SysWorkflowFormControls class to not be in the correct company context when trying to load the necessary workitems/actions for the record in question.
Solution:
My work-around for this is to perform a manual changecompany around the code in the SysWorkflowFormControls.showWorkItemActions method.
e.g.
changecompany(_workItemTable.CompanyId){...}I hope this helps someone resolve this rather strange error.
Regards
Jonathan
workflowax: Workflow – A view from above. Blog bot DAX Blogs 0 17.08.2010 16:05
Crm 3.0: custom workflow create email from template wb Dynamics CRM: Разработка 7 04.03.2010 00:02
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM, Email correlation and smart matching Blog bot Dynamics CRM: Blogs 0 12.11.2008 04:08
получение полей to,from из Email MFCшный Wizard Dynamics CRM: Разработка 3 12.09.2008 16:35
Microsoft Dynamics CRM Team Blog: Accessing a SQL Database from a Microsoft Dynamics CRM Plug-in Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 23:35.
