#1 |
In this blog you will find the source code in order to implement a client add-in based project with Windows Media Player. You would have a wide range of possibilities to use this simple add-in and enlarge this project on your own.
If you want to know more about client add-ins you can refer to MSDN link: Extending the RoleTailored Client Using Control Add-ins in Microsoft Dynamics 2009 SP1 [*]Run Table 2000000069 Client Add-in[*]Insert a new line with these values:[*]FieldValueControl Add-in Name Cronus.DynamicsNAV.NMediaPlayerPublic Key Tokendfcb4863cf7c4cb0 (this is an example)Version1.0.0.0DescriptionLet this Add-in Media Play[/list]DodgeBall rule 5 : DEVELOP your C/AL code
{ OBJECT-PROPERTIES { Date=; Time=; Modified=Yes; Version List=; } PROPERTIES { SourceTable=Table18; DataCaptionExpr=Text10000000; PageType=CardPart; } CONTROLS { { 1101100000;0;Container; ContainerType=ContentArea } { 1101100001;1;Field ; ControlAddIn=[Cronus.DynamicsNAV.NMediaPlayer;PublicKeyToken=dfcb4863cf7c4cb0] } } CODE { VAR Text10000000@1101100000 : TextConst 'ENU=LET NAV Play !'; BEGIN { WARNING ---------------------------------------------------------------------------- YOU NEED TO CHANGE THE PublicKeyToken WITH THE ONE ASSIGNED TO YOUR OBJECT !!! ------------------------------------------------------------------------------------ } END. } }
![]() This simple client add-in project may be used in, e.g.
Duilio Tacconi (dtacconi) Microsoft Dynamics Italy Microsoft Customer Service and Support (CSS) EMEA Источник: http://feedproxy.google.com/~r/Micro...of-course.aspx
