Старый 15.04.2011, 13:11   #1
workflowax: Business Connector code refresh
Источник: http://workflowax.wordpress.com/2011...-code-refresh/
While developing business connector applications you may come across issues where you code changes in AX do not seem to be taking effect or the caching is taking too long to refresh. I’ve tried restarting the AOS, restarting IIS, restarting Application pools even restarting the entire server and nothing seemed to have helped. However, an easy way to ensure that your changes are always available to the business connector code is to add the following line at the beginning of your .NET code, after loggin in, but before executing your custom code:
DynAx.CallStaticClassMethod(“SysFlushAOD”, “doFlush”);
(where DynAx is a logged in instance of Microsoft.Dynamics.BusinessConnectorNet.Axapta)
I hope that helps someone.
workflowax: No .NET Business connector session found. Blog bot DAX Blogs 0 02.11.2010 20:05
workflowax: Developing a business connector application Blog bot DAX Blogs 0 25.05.2010 23:05
workflowax: Dynamics AX WF Video: Building Business Process into your application Blog bot DAX Blogs 0 23.05.2010 08:06
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 12:53.
