Старый 07.09.2011, 17:11   #1
Axilicious:AX 2012 Navigation Properties
Источник: http://www.ksaelen.be/wordpress/2011...on-properties/
It’s been a while since I’ve posted, but here’s a small little post about what I think is a cool feature in Ax 2012!
In AX2009, when you have a table that has a relation to another table and you want to use it in code, you have to provide a method that performs a select on the other table and returned the related record. ( fe : SalesTable.SalesLine() ) Well this is something cool in AX2012. Here’s how you can do it now.
On the main table you have the relationship. There you can use a new property called CreateNavigationPropertyMethods and set it to Yes.
Once you have done this, there will be a method on you table that returns the related record.
Kashperuk Ivan: Tutorial: Table Relation properties in AX 2012 Blog bot DAX Blogs 3 09.05.2011 00:06
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 12:30.
