#1 |
emeadaxsupport: Microsoft Dynamincs AX 2009 Workflow: Notification message does not contain PO number
Источник: http://blogs.msdn.com/b/emeadaxsuppo...po-number.aspx
============== We recently came across problem with Workflow notification message. We have set up template workflow for process Purchase requisition approval (PurchReqApproval). When purchase requisition gets approved the process should create automatically Purchase Order (setting parameter “Auto create purchase order” in Accounts payable > Setup > Parameters on tab Purchase requisition). For even Completed we set up following notification: “Purchase requisition order: %Purchase Requisition.PurchReqId% has been approved and new purchase order was created with number: %Purchase Requisition.Purchase requisition lines.PurchId%”. After workflow has finished correctly the notification was sent. The problem is that notification looks following: “Purchase requisition order: PR_000501 has been approved and new purchase order was created with number: ”. So the second place holder: %Purchase Requisition.Purchase requisition lines.PurchId% has not been replaced correctly, although the Purchase order was created correctly. The purchase order is created and field PurchReqLine.PurchId is filled in in following code: \Classes\PurchAutoCreate_PurchReq\createPurchLine \Classes\PurchAutoCreate\create \Classes\PurchAutoCreate_PurchReq\create \Data Dictionary\Tables\PurchReqTable\Methods\setWorkflowState \Classes\PurchReqWorkflowEventHandler\completed \Classes\SysWorkflowEventDispatcher\raiseWorkflowEvent \Classes\SysWorkflowEventDispatcher\onWorkflowCompleted while the notification is sent a little later \Classes\WorkflowDocumentField\substitutePlaceholderAsUser \Classes\SysWorkflowEventDispatcher\sendNotifications \Classes\SysWorkflowEventDispatcher\onWorkflowCompleted As we can see from the \Classes\PurchAutoCreate_PurchReq\createPurchLine the value of PurchLineReq.PurchId is updated between more than one pairs of “ttsbegin” and “ttscommit” and the query of the field is executed before the last “ttscommit” and the value will not be written into the database until the last “ttscommit” is executed (I have verified this by checking the database in SQL Server when debugging). In method \Classes\WorkflowDocumentField\substitutePlaceholderAsUser we have following code X++: if (_userId == curuserid()) { result = WorkflowDocumentField::substitutePlaceholder(args); } else { new RunAsPermission(_userId).assert(); // BP deviation documented result = runas(_userId, classnum(WorkflowDocumentField), staticmethodstr(WorkflowDocumentField, substitutePlaceholder), args, _companyId); CodeAccessPermission::revertAssert(); } Every time an application connects to SQL Server, a new connection (or SPID) is created. That means in the method Runas a new AX session is created and it will build a new connection to the database while searching a value in database but the new connection can’t read the uncommitted data of the old one, so I think it is right behavior that we can’t get the value by using Runas method. This is why the placeholder: %Purchase Requisition.Purchase requisition lines.PurchId% was not replaced correctly. So the simple workaround is to change above code to not run with runas. Although you need to be aware that it can imply some security problem when you have record level security set up on table PurReqLine. --author: Czesława Langowska Vliegen --editor: Czesława Langowska Vliegen --date: 22/Sep/2011 Источник: http://blogs.msdn.com/b/emeadaxsuppo...po-number.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 22.09.2011 в 15:11. Причина: оформление |
