#1 |
emeadaxsupport: AX for Retail: Receipt footer is not displaying Tax information
Источник: http://blogs.msdn.com/b/axsupport/ar...formation.aspx
============== Issue description: The customer adds the TAX information in the receipt footer, but the information is not printed on the receipt. The issue has been identified to be a problem with the Seed data that is inserted when running the HQ/Setup/Parameter/Initialize In the POSISFormlayout we have a FooterXML field for each report, which consist of a long string like. Example 3C6865616465723E0D0A20203C6C696E65206E723D223030222049443D225465787422204E756D6265726F66436F6C756D6E733D223536223E0D0A202020203C63686172706F7320 The POSISFormlayout data is being inserted through the DRMSeedDataGenerator that calls AOT/RESSOURCES/RBO_Footer_1_txt ![]() The workaround is export the R1 demo data from POSISFormlayout table and field FooterXML Then export the resource from your R2/R2 Refresh and replace the string from the R1 data and import it back. After that you can run the Retail HQ/Setup/parameters/initialize The result is that the footer lines with the tax is printed ![]() Corrected file added that can be added to the AOT/Ressources Author: Kim Truelsen Blog date: 9-2-2012 Источник: http://blogs.msdn.com/b/axsupport/ar...formation.aspx
