Старый 13.06.2012, 16:11   #1
ax-erp: Dialog selection Criteria
Источник: http://microsoft-dynamics-ax-erp.blo...-criteria.html
I will assume you use the RunBase framework.
For the dialog part of your question see Axapta Dialog Validation.
To show the query dialog, you must provide two methods:
public boolean showQueryValues()
return true;
and
public QueryRun queryRun()
return queryRun;
The queryRun method must return a valid non-null value.
The queryRun instance variable is usually assigned a value in the unpack and initParmDefaultmethods.
Take a look on the CustInterestCancel class for a concise example.
How to disable the select button: return false from showQueryValues.
ax-erp: X++ Code to get the Ranges / Criteria from Query Blog bot DAX Blogs 0 12.06.2012 12:11
dynamics-ax: A Guide to Microsft Dynamics Cloud ERP - Dynamics AX Blog bot DAX Blogs 0 15.04.2011 00:12
Часовой пояс GMT +3, время: 17:36.
